Vinson Starting Question
Old Oct 16, 2005 | 08:24 PM
CatsRule's Avatar
Default Vinson Starting Question
Hey everyone. When i start my 05 vinson i get a ticking sound and it wont start. So i charged the battery and then it was ok, drove it all day and everything was fine. Next day went to start it, same thing just keeps ticking. Could this be just a bad battery or could it be the charging system is not keeping the battery charged. The lights turn on and everuything but it just doesnt have enough to get it to turn over. Thanks
Old Oct 17, 2005 | 10:24 PM
slabnabber's Avatar
Check all connections if good swap battery.
Old Oct 18, 2005 | 02:00 PM
wayoverpar's Avatar
try checking the charging systym and all your fuses, good luck
Old Oct 18, 2005 | 03:13 PM
CatsRule's Avatar
Thanks guys. Went to my dealer yesterday and he said he replace the battery under warranty. If it keeps doing this hes going to check my charging system. Oh any of you use a battery tender when your machine is in the garage. Would it be ok to leave it hooked up all winter?
Old Oct 18, 2005 | 04:14 PM
hondabuster's Avatar
Yep, thats what they are designed for. Just hook up the battery tender...and forget about it.
Old Oct 18, 2005 | 05:13 PM
pads's Avatar
A quick check of your charging system (this doesn't find all problems) is to check your battery before you start the machine with a voltmeter. Then check the system with the machine running. If your systems is working the voltage running will be higher than while the machine is off. Yes, a battery tender is a good thing. Don't use a battery charger because it puts out too much amperage (usually about 2 amps). A battery tender puts out less than one amp.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
kwackermann
Jun 24, 2015 10:18 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
