Reverse Rev Limiter (Z400)
Old Oct 19, 2005 | 05:51 PM
strongtyerYFZ's Avatar
Default Reverse Rev Limiter (Z400)
I am wondering if there is any way to get ride of the rev limiter in reverse. Its kinda annoying sometimes. I have a BIG GUN CDI but I dont know much about it because i bought the quad used just about 3 weeks ago. Is there any way to program the CDI to stop the rev limiter for reverse or raise the rev limit?
-StrongTyer
Old Oct 19, 2005 | 06:52 PM
dvxxvd's Avatar
I know there is a way that works for the 2003's it is on the fourms somewhere if you do a search on it i was wondering if the same process will work on my 2005 i tried but was unsure of how to get the pins out.
Old Oct 19, 2005 | 06:55 PM
dvxxvd's Avatar
This was posted a while ago by freakazoid sorry i don't know how to quote you correctly
Freakazoid
Michigan
Wed January 15, 2003 7:37 AM Message OptionsSubscribe to ThreadE-Mail ThreadPrivate Message UserPrint Thread
LT-Z400 reverse rev limiter disabler.
You can do this which will have all indicator lights working and the rev limiter set to 9000 for all gears and neutral, just like the factory setup.
All changes will be made to the CDI connector.
The pins on the connectors come out easy. Just unplug it from the CDI unit and as you look into the connector with the lock on the top, take a small screw driver and slide it in just above the pin you want to remove then pull on the wire.
1)Disconnect the black wire with the red trace and the blue wire with the black trace and put a piece of shrink tubing over each one of them and put a dab of silicone in the hole the wires came out of.
2)Pull out the black wire with the brown trace and the black wire with the white trace. Keep track of the hole they came out of. Make a small jumper wire (approx. 28 ga.) about 2" long, slide it under the rubber seal on the black/brown wire connector pin and solder it to the pin. Do the same with the other end of the jumper and solder to the black/white wire connector pin. Now put these two pins back in there respective holes. Put a dab of silicone between the jumper wire and the wire it is next to.[img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 19, 2005 | 07:29 PM
garrett5462's Avatar
Freakazoid
Michigan
cool info man [img]i/expressions/face-icon-small-smile.gif[/img], i might try
Old Oct 19, 2005 | 08:31 PM
Hmm... sounds a little more complicated than I thought... Is this process the same with an aftermarket rev limiter? Is there any way to program the rev limiter to just eliminate the reverse rev limiter or not? And what is the rev limiter set at stock? 9000 according to that post right?
Thanks for that info tho. I might try that... sometime.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 19, 2005 | 08:51 PM
dvxxvd's Avatar
Sorry guys thats all i know you will have to wait for the brains to send back
Old Oct 20, 2005 | 01:24 PM
witti's Avatar
Yes the stock limiter is 9000. I did this mod and it works great. Now with my Dyna CDI my rev limiter is 10500rpm's foreward or reverse.
Old Oct 20, 2005 | 11:04 PM
So thats the only way to raise your rev limiter for reverse? With that mod... hmm... I'll have to do it sometime...
Old Oct 21, 2005 | 09:59 AM
witti's Avatar
Im not sure if its the only way, but it works, and its free.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
