Question on brake fluid
Old Dec 7, 2005 | 09:02 PM
akarotten's Avatar
Default Question on brake fluid
I,ve just replaced brakes on my 94 mod ltf-250 quadrunner,I cant read writing on master cylinder,is brake fluid any different then car type fluid?
Old Dec 7, 2005 | 11:59 PM
IdahoVinnie's Avatar
My owners manual says to use DOT 4, and nothing else.
I don't remember what a car uses. It may be different, primarily because an atv may heat up the fluid to a higher temperature than a car does--therefore requiring a fluid that will stand up to the higher temps.
Old Dec 8, 2005 | 09:47 PM
mucky's Avatar
I would go with the dot 4 fluid its better for heat
most cars and trucks run dot 3
Old Dec 12, 2005 | 12:58 AM
cyanidetrece's Avatar
i run dot 5 in my lt230s. it's silicone brake fluid, does not absorb moisture or damage paint like dot 3 or 4. and it has a higher boiling point as well. i just bleed the whole system untill all the old brake fluid was out. i did this about 9 or 10 months ago and have had no trouble. you can use dot 5 in any brake system, but if it's dot 5 to begin with you have to use dot 5. just my two cents.
Stirling
Aug 9, 2015 01:49 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
DeFox500
Jul 26, 2015 06:32 PM
Sandman2.0
Jul 21, 2015 09:03 AM
rcappie4
Jul 10, 2015 04:54 PM
