Cams for kfx/z 400
Old Dec 18, 2005 | 05:02 PM
Warrior02man's Avatar
Default Cams for kfx/z 400
I want cams for my 03 KFX for more power.. wat should i get? I ride trails mainly and race sometimes. Just post how much and what they are called.. and if u want the site would b great.. thx.
Old Dec 18, 2005 | 08:45 PM
mucky's Avatar
hot cams and web cams. cost around $150 each give or take alittle
do a lot of research before you decide what you want
you will get lots of opinions on both. and also it depends on
if you install only 1 cam or both. 1 will give you bottom end ( not sure which one, exhaust or intake )
and both helps you on the top end. I have hot cams and have had great success with them.
good luck
Old Dec 19, 2005 | 06:53 PM
witti's Avatar
I also have hotcams and have had good success.
You can get both hotcams (stage 2) for ~$240 from woodward specialties. Stage 1 is the intake cam only ~$120. The intake only is for low/mid range power. Most people that get the intake cam only, end up installing the exhaust cam later.
If I did it over I think I would go with web cams. They cost a little more, but they seem to give more power and there lighter. Lighter cam = less rotating mass = better/easier reving engine and less stress on the timing chain.
Old Dec 20, 2005 | 06:15 PM
MURDR's Avatar
I have the hotcams Stage II cams for sale . I have pics i can email.
Old Dec 21, 2005 | 10:04 PM
knauf's Avatar
New, Used, How much u asking? wallsaw1@sbcglobal.net. Thanks.
Old Dec 22, 2005 | 10:18 AM
03hmfz's Avatar
I have the hotcams but don't know how much they helped cause I rebuilt the whole motor including head work at once. Mine runs stronger than most 450s.
Old Dec 22, 2005 | 11:30 AM
MURDR's Avatar
03hmfz you should try and run the hammer head piston in your quad. I heard they make alot of power from Z400 centrl forum. I sent that email about the cams
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
