eiger spark aresster
Old Dec 19, 2005 | 07:06 PM
teven's Avatar
Default eiger spark aresster
I have an 05 Eiger, In the manual is says to clean the spark arrester, but mine seams to be welded in, has anyone had this problem?
Old Dec 19, 2005 | 07:13 PM
ajporter03's Avatar
I have an 05 Eiger as well. I ran into the same problem. The spark arrestor isn't welded in. I had one heck of a time pulling it out. I thought that I was doing something wrong, but I wasn't. All of the sudden, it just broke loose and came out. Just make sure that you pull the screw out first, or you wont get anywhere. I also sprayed it with some penetrating oil to loosen it up.
Old Dec 19, 2005 | 07:17 PM
teven's Avatar
THANKS, i will give it a try.
Old Dec 19, 2005 | 10:59 PM
rolsmojave3's Avatar
i used the Crude but effective vise grips...then hit them with a hammer...then it finally came...i sounds good without the sparky in there...kind of like a mellowed down HMF
Old Dec 20, 2005 | 07:38 PM
teven's Avatar
I shot some wd 40 behind the lip and it came right out. thanks for the tips.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 20, 2005 | 11:28 PM
teven's Avatar
If you take the screen off the spark arrester do you need to rejet for this?
Old Dec 21, 2005 | 01:36 PM
Back40's Avatar
I cut the screen from my spark arrestor and did not notice a difference before I installed a jet kit. However my eiger was running lean to begin with. May not be an issue depending on the elevation you ride.
Old Dec 21, 2005 | 01:49 PM
teven's Avatar
just dont want to ruin any engine parts.
Old Dec 22, 2005 | 10:57 AM
Back40's Avatar
Have you checked the plug color? That will tell you if it is running lean, rich, etc.Spark plug coloration
Old Dec 22, 2005 | 05:54 PM
i modded my air box, removed the arresstor and jetted up....made a noticable difference.
