vinson carb problem???????
Old Jan 19, 2006 | 11:17 PM
SuperSuzuki4's Avatar
Default vinson carb problem???????
I just put my pipe and jet kit in and its not quite right. I put a K&N in also. Well it starts and idles fine but you hold the throttle a .25 the way and it stumbles some. You can open her up and she is pretty smooth but when you let off she pops a few times. Please help me out a little. I may need a bigger size pilot.
Old Jan 20, 2006 | 10:52 AM
camozuki's Avatar
Here is a link to some pretty good info.
http://forums.atvconnection.com/mess...ord2=tuning%20
My vinson also runs a little rich and has an occasional pop out of the exhaust, but a little rich is ok. Have you tried adjusting the mixture screw?
Old Jan 20, 2006 | 02:51 PM
hondabuster's Avatar
The pop in the exhaust on throttle let off, is a lean idle circuit. Look for air leaks, and if thats ok, turn the mixture screw out 1/4 turn or maybe even more
Old Jan 20, 2006 | 04:20 PM
With the mixture screw I cant get it where it needs to be. I am pretty sure I need a bigger pilot.
Old Jan 20, 2006 | 04:34 PM
With this kit it says 3 turns out on mixture and 2.5 above 5000 ft. So that means out is richer right? How much father than 3 turns can you go?
Old Jan 20, 2006 | 06:08 PM
about 4 turns out is max, if thats not enough, go up one on the pilot jet.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
