No Reverse Lo Range on Eiger 5sp?
Old Jan 23, 2006 | 03:55 AM
zerowick's Avatar
Default No Reverse Lo Range on Eiger 5sp?
is there only one reverse speed on the manual shift Eiger? is it the same ratio as 1st high range and would this be an issue towing heavy loads?
thanks
Old Jan 23, 2006 | 09:53 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
There is only one reverse range. I can't find my book to confirm it, but I'm pretty sure that the reverse ratio is the same as low 1st gear.
Jaybee
Old Jan 23, 2006 | 02:29 PM
zerowick's Avatar
thanks
Old Jan 23, 2006 | 05:54 PM
rolsmojave3's Avatar
reverse is a pretty high gear...i'd say the ratio is inbetween 1st and 2nd high.....it's not really an issue because you can manipulate the foot clutch to bring the revs up and disengage the clutch
Old Jan 24, 2006 | 01:44 PM
zerowick's Avatar
foot clutch? at times I have near 1000 pounds behind me, will this trans hold up?
Old Jan 24, 2006 | 06:03 PM
is it on wheels, or dead weight....i've pulled a dodge caravan and old jeep with a 302 V-8 with no prolbems up little hills...very litttle hills
ReconBayou
Oct 31, 2022 05:37 PM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
r1pilot83
Sep 27, 2015 07:38 PM
