? z400/kfx
Old Feb 15, 2006 | 09:28 AM
kawiking's Avatar
Default ? z400/kfx
im getting ready to put in a stage 2 hotcams,and a 13.5:1 piston. what size of main jet do you think i'll need??
im going to be running vp-c12 race gas. should i go up 2 on my pilot? i have a 165 main in right now.
Old Feb 15, 2006 | 04:55 PM
z838mx's Avatar
Default ? z400/kfx
im running a 168 main in my z with a 450 stroker 13.1-1 piston ported head and custom grind race web-cams. Hope this helps
Old Feb 16, 2006 | 12:52 AM
kawiking's Avatar
Default ? z400/kfx
is that a stock carb? what did u go to on your pilot and what is your needle on? thanks.
Old Feb 16, 2006 | 08:30 AM
z838mx's Avatar
Default ? z400/kfx
With the stock carb it was a new needle from alba in the middle setting with a 160 main and stock pilot I run a 1mm fcr now with this motor. but with my 440 I ran the stock and had what I said now its a 168. I dont know the altitude you are at but it should be close to that for base settings.
Old Feb 16, 2006 | 10:57 PM
omar's Avatar
Default ? z400/kfx
Hey let us know how your 400 runs after you put the piston and hotcams. and the difficulty if you are installing yourself.
Old Feb 17, 2006 | 08:53 AM
z838mx's Avatar
Default ? z400/kfx
The hotcams make more of the difference then the piston. but its nice to do them together. Its worth the investment to do the cams and piston makes a good difference. I would add an ignition at the same time so when the cams start to pull your not stopping that by the rev limiter.
Wigglez1014
Feb 15, 2007 03:17 PM
Wigglez1014
Feb 15, 2007 02:02 PM
Budwiser
Jun 21, 2006 12:16 AM
Sledhed88
Jun 28, 2005 12:34 AM
iiijay743iii
May 12, 2005 06:46 PM
