LT250r?? please hellp big question
Old Feb 25, 2006 | 04:03 AM
superevil's Avatar
Default LT250r?? please hellp big question
here goes. It doesnt matter what the frame says,if you have a 6 bolt intake then your cylinder is an 88.The only diferences between 87 and 88 are: diferent piston,cylinder,cylinder head,reeds,reed boot.I have a 1988 motor in a 1987 frame as well. My 88 motor has an 87 head on it too. If you are running way to rich just take the jet you have to a shop like the guy above said,and go down 1 size at a time till its right.Then you can fine tune it with the needle clip,hope this helps.
Old Feb 25, 2006 | 10:46 AM
LT80's Avatar
LT80 Expert
Tolerance:: a new bore would have .003. up around .010 would be max IMO.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
