lt250r oil????
Yes you do. Take out the drain plug in the bottom of the motor like any other motor. The filler plug is on the right(when sitting on it) side of the motor. I believe it is 900ml of oil. Be sure to use a quality oil in it. I use Bel-Ray Gearsaver and dont have any complaints.
It's transmission oil not regular oil. Go to your dealer and get some any motorcycle specific oil will work but make sure it's for a motorcycle don't put regular oil in there. I like Bel-Ray Gear Saver also.
