z400 mixture screw location?
Originally posted by: Camds650
The mixture screw is in the bottom of the carb, but you have to drill out the factory plug that is covering it.
Originally posted by: yoshz
The air-fuel mixture screw does not have to be drilled out on the Z400. There is a rubber cover that can be removed to access it. It is on the bottom of the carb and faces towards the front of the bike.
10-10-2015 10:20 AM
