REPLACING STATOR LT250r need HELP
Old Mar 27, 2006 | 01:15 PM
GFORCE2574's Avatar
Default REPLACING STATOR LT250r need HELP
Ok I got the LT250r stator cover off. How do I keep the stator cover from spinning when I try to loosen the retaining nut? I don't want to wreck stuff trying to invent my own way. Im sure there is an eay way to do it. Any help would be greatly appreciated.
Old Mar 27, 2006 | 05:50 PM
1987LT250's Avatar
are you refering to the fly wheel and the flywheel nut on crank? if so i put in gear and hit mine with impact gun it will come off easy.
Old Mar 27, 2006 | 08:16 PM
GFORCE2574's Avatar
Thanks for the tip. I figured out it was the flywheel just after I posted.
Old Jul 14, 2012 | 05:29 PM
scatto420's Avatar
how did u guys get off magneto off
Old Jul 15, 2012 | 09:11 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Pull the sparkplug. Get a soft piece of nylon rope about 1.5ft long, stuff half of it in the sparkplug hole. The rope will stop the piston and you can loosen the nut. You will need a puller to remove the flywheel. It threads into the flywheel with lefthand threads.
Jmuddin284
Jan 19, 2026 07:16 AM
STLyamwar
Jul 25, 2020 04:44 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
toonces
Jul 28, 2015 01:58 PM
