Flywheel removal Lt250r
Old Mar 28, 2006 | 03:22 PM
GFORCE2574's Avatar
Default Flywheel removal Lt250r
I have the retaining nut off the Lt250R flywheel. It is still stuck on tight. Do I use a 3 jaw puller or should it just pull off?. Are there any things I need to note before pulling it off (positon)? Any tips would be appreciated. Replacing this stator is proving to more involved than I thought any knowledgable tips would be greatly appreciated.
Old Mar 28, 2006 | 03:33 PM
nobrakesjake's Avatar
A 3 jaw puller would be the easiest way...dont want to pry it off.....the only other way would be to tap easy around it...but doing that would take chance of breaking something...besides you ll want to have a puller around for future use.
good luck
Old Mar 28, 2006 | 04:58 PM
GFORCE2574's Avatar
Thanks for the info.
Old Mar 28, 2006 | 10:56 PM
gassrx's Avatar
lock tite the nut on with blue lock tite and only tor to about 5 footpounds under specs . this will prevent the fliwheel from spreding and letting the keyway slip.
Old Mar 29, 2006 | 11:45 PM
superevil's Avatar
the best way to remove a flywheel is a with a flywheel puller,if you look at the inside of the flywheel middle youll notice its threaded. a flywheel puller pulls on the flywheel and pushes on the crank.they can be bought for about 12 bucks at almost any quad/dirtbike shop,and the same puller will fit tons of diferent machines
Old Mar 29, 2006 | 11:58 PM
Duneaddict's Avatar
Ditto...
Don't use a 3 jaw puller... drop the $12 and get the correct puller. Your flywheel will thank you later.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Levi Enstad
Sep 26, 2015 08:00 AM
