LTR 450 Tether Wiring
Old Apr 8, 2006 | 03:42 AM
SandyBear's Avatar
Default LTR 450 Tether Wiring
Im in a crunch and received the PRO ARMOR race tether today from Brown without any instructions. Go figure. Has anyone installed one on on their 06 LTR 450 yet? I have no wiring diagram available and I need to know which is closest wire to the stator under the front fenders. Dealers service dept is closed and I race on Sunday.
Thanks,
Bear
Old Apr 8, 2006 | 06:05 AM
SandyBear's Avatar
Found it. Works great. Thanks.
Bear.
Old Apr 30, 2006 | 04:55 PM
PIEMANN's Avatar
HI YOUR TETHER SHOULD HAVE ONE SHORT AND ONE LONG WIRE FIT THE SHORT WIER TO AN EARTH ANYWHERE UNDER THE HEADLIGHT THEN IF YOU SIT ON YOUR BIKE THE COIL IS ON YOUR RIGHT SIDE YOU WILL SEE A WHITE WIRE THIS IS WHERE YOU FIT THE LONG ONE JUST SPLICE INTO IT THEN THATS IT JOB DONE
Old May 1, 2006 | 04:29 AM
tlronny's Avatar
As an alternative to the post above you can connect the n/o switch to the white wire on the left side near the top shock mount which runs to the stator with a blue wire.
Ground the other switch wire to the chassis. (A good spot is the cable keep bracket jst below the bar clamp.)
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
