z400 timing chain adjustment
Old Apr 20, 2006 | 10:25 PM
JTH's Avatar
JTH
Default z400 timing chain adjustment
I just bought a 03 z400 and I would like to see how to check/adjust the timing chain on it. And is there anything special you have to do to change the coolant in it.
Thanks
Old Apr 20, 2006 | 10:38 PM
rolsmojave3's Avatar
It's automatic...you shouldn't have to mess with it. With that said, I know on my Mojave (DOHC) the chain should only have 4mm of play between the intake and exhuast sprockets.
Old Apr 22, 2006 | 10:45 AM
JTH's Avatar
JTH
I've seen some posts about checking the number of clicks on the adjuster anyone have a explaination of how to do this. It just seems a little loud at low rpm but I'm not completly sure all I've ever ridden are hondas.
Thanks
Old Apr 22, 2006 | 03:38 PM
mucky's Avatar
with an 03 its probably due for a timing chain if the quad was rode a lot. stock chains do tend to stretch
and changing the coolant is easy. just remove the bottom radiator hose from the motor and let it drain
then flush with clean water and then reinstall the hose and fill with new coolant
Hankey Pankey
26
Oct 18, 2020 03:50 PM
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
yambam13
Jul 4, 2015 01:49 PM
JBibb
Jul 4, 2015 10:16 AM
