Z-400 valve specs
Old 05-01-2006 | 07:25 PM
BigDimo2624's Avatar
Default Z-400 valve specs
if i were you i wouldnt waste my money, new shims shouldnt be necessary at all, especially since its not old. ive rebuilt an OLD honda interceptor crotch rocket and new shims werent needed. all that you need to do is adjust the valves with the gauge and you should be fine. but you have to have the piston at the right position. unless the mechanic at the dealership sais its totally necessary i wouldnt waste your money, but then again thats just me.
Old 05-01-2006 | 07:31 PM
chili3's Avatar
The only way to adjust the clearance is by changing the shim under the puck. There is no adjuster on the rocker like most have. I am a auto tech and a lot of imports do this and it sucks to adjust the valves.
Old 05-01-2006 | 07:36 PM
haha alright my mistake
Old 05-01-2006 | 07:41 PM
chili3's Avatar
Most people don,t understand how they work until they see it.
  #15
Old 05-01-2006 | 07:47 PM
i guess not
  #16
Old 05-01-2006 | 11:01 PM
mucky's Avatar
Originally posted by: maczzz
I think mucky means .1mm to .2mm or (.0039-.0078 inches)
I was tired when I typed it and had it backwords. what you show is correct
and if you know what size shim you need you can sometimes buy it from the dealer
without getting the whole kit for around $80. and adjusting your valves is part of keeping your bike running
in top shape. its easy to do but it does take a little time
  #17
Old 05-01-2006 | 11:15 PM
chili3's Avatar
I just checked the valves, intake at 6thou, exhaust at 8 thou. Checked t-chain adjusted and was on last click. Has any one ever used one of those aftermarket adjuster,s, or am i better of just replacing the chain and guide,s?
  #18
Old 05-01-2006 | 11:25 PM
mucky's Avatar
I run one and havent had a problem yet. it does take a while to get the feel of it so you dont have it to tight
and if its a stock chain I would replace it with new guides. they may not look worn but where the tensioner pushs
on it wears and DID makes a nice timing chain for the Z for about the same price
  #19
Old 05-02-2006 | 12:35 AM
chili3's Avatar
If I put my finger in the tensioner hole I can feel a deep wearspot on the guide. Since I am selling the quad to my neighbor I am going to replace the t-chain and guide. Where is the best place to guy a DID chain from? And do they also sell the guides?
  #20
Old 05-02-2006 | 09:17 PM
mucky's Avatar
this is where I got my chain from chain
try here for the guides guides
Scooter's Shop
23
10-22-2015 07:04 PM
wrencher82
09-30-2015 04:27 AM
wrencher82
09-28-2015 10:02 PM
2many2ride
09-27-2015 04:35 AM
maveikfe
1) Engine problems..
09-24-2015 10:36 PM
Quick Reply: Z-400 valve specs
