Which Gear Oil Do I Use?
Old May 11, 2006 | 10:55 PM
GrnXnham's Avatar
Default Which Gear Oil Do I Use?
It's time to change the gear oil in the rear differential in our Suzuki Ozarks.
The manual says to use SAE90 GL-5 gear oil--or if riding a lot with temperaturess below 32 degrees F then use SAE80.
Problem is that I can't find either of these gear oils anywhere. The closest I can find is SAE80-90. Is it okay to substitute one of these? Everything is multiweight around here.
BUT LET ME GUESS... My Suzuki dealer probably has "special" SAE90 gear oil for $50/QT as opposed to the $5/QT stuff at the autoparts stores and I need to buy the Suzuki brand stuff, right?
What does everyone else use?
Old May 12, 2006 | 10:56 AM
baveux2's Avatar
You are perfectly protected with any of the SAE GL 5 80w90 gear oil,
Old May 14, 2006 | 11:19 PM
GrnXnham's Avatar
Okay, thanks for the help.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
