Hot cams?
Old Jul 11, 2006 | 04:11 PM
SMOKINZ's Avatar
Default Hot cams?
j/w what a hot cam does and how they work.
Old Jul 11, 2006 | 06:02 PM
kawiking's Avatar
Default Hot cams?
do you know what a cam does? a hot cam just gives the valves more lift. intake and exhaust. the stage 1 cam is just intake i think, stage 2 is both cams.
Old Jul 11, 2006 | 06:51 PM
SMOKINZ's Avatar
Default Hot cams?
well are they worth looking into, what brand, how much, and how hard are they to install?
Old Jul 11, 2006 | 07:07 PM
garrett5462's Avatar
Default Hot cams?
HotCams is the brand...
they give lots of top end power if you allready have a good intake and exhaust system, otherwise you dont get much from them, and if you have a manual you can put them in yourself.
Old Jul 11, 2006 | 08:46 PM
yellowrider250ex's Avatar
Default Hot cams?
I would get Web Cams Thay are said to be lighter and give more power than hotcams.
Old Jul 11, 2006 | 09:03 PM
kawiking's Avatar
Default Hot cams?
they cost almost twice as much and you have to give them your stock cams to. a stage 2 cam set is all you need. a bigger carb and porting will help you alot, big bore or high comp. im wanting to get mine ported .
Old Jul 12, 2006 | 12:55 AM
mucky's Avatar
Default Hot cams?
a set of hot cams will run around $250/300 for the set.and they're easy to install if you have done it before. but then you need to have the valves readjusted. and that takes time, you have to install and measure, remove and replace valve shims and start all over till you get the clearance you need
and web cams are nice but cost a little more and like what was said before you have to send them your old cams for the core charge
Old Jul 12, 2006 | 02:56 AM
SMOKINZ's Avatar
Default Hot cams?
Well I think I might need some help if I do get them. Dont suppose anyone around my area willing to help?
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
