Ozark carb
Old Jul 14, 2006 | 03:23 PM
Zark's Avatar
Default Ozark carb
I'm trying to get into my Ozark's carb to hopefully install a Dynojet kit. How do I get into? Suggestions greatly appreciated. Thanks.
Old Jul 14, 2006 | 03:42 PM
bombrider04's Avatar
Default Ozark carb
http://216.37.204.203/Suzuki_OEM/Suz...=13&A=100&B=10
this should help
Old Jul 15, 2006 | 02:29 AM
Zark's Avatar
Default Ozark carb
wow, that was very informative. thanks. but what i ws trying to get at was, how do get access to the carb? shall i remove the air box or the gas tank?
Old Jul 15, 2006 | 08:37 AM
Default Ozark carb
I will look at mine later on today but I gotta work but ill get back to you in that one for sure.
Brett
Old Jul 16, 2006 | 12:42 AM
Default Ozark carb
sorry for the late reply it was a long day to get the carb out try taking the side pannel off of the ozark so that it is easily visible then the carb is mounted to the airbox so disconnect that and diconnect the throttle lines, fuel lines(I usually after shutting the gas off at the petcock stick screws in the lines and tape them up so gas won't keep coming out and maybe get dirt in them) then undo the carb from the intake manifold and you should be set.
Old Jul 16, 2006 | 01:32 AM
Zark's Avatar
Default Ozark carb
thanks so much. hopefully i can rejet them soon.
Old Jul 16, 2006 | 12:41 PM
Default Ozark carb
yea no prob it should come out that way I have never taken mine out but if not then the easiest way from then on would be taking the airbox off but try what I said first good luck.
Old Jul 17, 2006 | 10:26 AM
91CavGT's Avatar
Default Ozark carb
I was able to rejet mine just by loosening the hose clamps up, and then rotating the carb.
The stock screws were soo tight though that I had to change them out for bolts. It made it MUCH easier to rejet the carb at that point. This is pretty much a needed thing to do if you rejet as often as I do!!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
traumajunkie
Jul 5, 2015 03:03 PM
