2000 LT 80 fuel leaking out of exhaust?
Im a carpenter not a mechanic so i could use some help? the electric start would just click at the relay so i thought the starter or relay were bad. i just learned about the reset switch under the fender, so i reset it and it and hit the start button. It turned over then fuel leaked out where the exhaust bolts to the motor. I think it has something to do with the valves but like i said my main tool is a hammer. Any help would appreciated! Thanks
I checked the fuel shutoff it was on. It is leaking quite a bit of fuel when i crank it over. It cranks until it kicks the reset switch under the right fender. The exhaust gasket on the pipe is shot and a bolt is missing from the flange. Thats why i can see the gas drizzling out by the motor. Thankful for the replies!!
My sons lt did the same thing. The fuel petcock is a bad setup. You can't manually shut it off. After a while they get gummed up or go bad and then the fuel bleeds by all the time. I went to pull the carb off and it leaked by no matter where I put it. I pulled the plug out of the bottom of the muffler and fuel dumped out. Then I turned the motor over with the pull rope because my starter is shot now and shot gas out of the intake on the cylinder and out of the exhaust. I also stood the bike up on its rear tires and then set it down and picked the rear end up and dumped it out the intake. I just kept doing this over and over till I got most of the gas out of it, put the carb back on and then was able to get it to start. I am putting a shutoff valve between the petcock and carb now.
bpegram84
07-22-2015 08:15 AM
