Aluminum wheels for LT80?
Old Dec 2, 2000 | 01:01 AM
Yamahahaha's Avatar
Does anyone know what offset and size combination I should be looking for to widen my sons LT80?
87 Warrior, FZ600 motor
90 Mojave, under the knife for EX500 motor
87 LT 80, gets rolled every weekend!
Old Dec 2, 2000 | 02:04 AM
250r89's Avatar
could you explain a little bit more about the lt580 and mabey ill be able to help you out?
Old Dec 2, 2000 | 02:32 AM
Yamahahaha's Avatar
I want to put wider tires on the rear and increase the track width in the front but retain the stock wheel width. I do not know what offset wheel I should be looking for.
Old Dec 2, 2000 | 03:25 AM
95wolv's Avatar
James Lucky Racing makes a 6" widening kit for the front, I'm sure you could find a wider axle, or wheel spacers for the back. It would be cheaper than replacing all the rims, hope that helps
Old Dec 2, 2000 | 12:39 PM
snowshark's Avatar
You will probably have to get some aluminum rims in order to get wider tires. One of our club members put some wider tires on the LT-80 with Douglas .125 rims. We added wider tires on our E-ton & had to put on some aluminum rims also.
That was one of the problems with the LT-80 is its tippy but after you add the wider tires you will be amazed at the difference.
Old Dec 3, 2000 | 02:10 AM
Yamahahaha's Avatar
Thanks guys, I plan to get the douglas .125's just did not know what offset (backspacing) to order. I bet they will have a good idea of what I need. Thanks again
Old Dec 5, 2000 | 12:14 AM
norcalatver's Avatar
My sons LT-80 has the james lucky front a- arm extensions w/maxxis front tires (20"). The rear has 2" offset douglas aluminum rims with 18" rear maxxis tires. He hasn't been stuck or rolled his quad since the conversion a year and a half ago.
Joe454
Nov 20, 2020 01:19 PM
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
