lt500r oil change help
Old Sep 17, 2006 | 11:34 PM
TBAS's Avatar
Default lt500r oil change help
When I changed my oil and refilled it the oil didn't make it to the check window on the front of the motor. I added oil until it wouldn't take any more. Still I can't see any oil through the window. Is this normal? I ran the motor a little bit and oil comes out the breather on top of the motor. I can only see a little oil through the window. Am I doing something wrong?
Old Sep 17, 2006 | 11:41 PM
Boomer2's Avatar
I'd find out how much oil it is supposed to take and add that much. The glass on my blaster became cloudy so I can't tell how much oil is in it. on my 250r therre is a screw you take out an oil flows out when it is full. To much oil in the transmission is bad, you blow the seals out of the transmission.
Old Sep 18, 2006 | 12:34 AM
TBAS's Avatar
Does anyone know how much oil a LT500r should take?
Old Sep 18, 2006 | 01:52 AM
TBAS's Avatar
I found out I put way to much oil in. I needed about 1.06 quarts and I put in 4. There is a screw just below the rear brake lever that lets you know you have thright amount of oil when removed. Thanks for your help.
Old Sep 18, 2006 | 07:04 AM
Boomer2's Avatar
Nice quadzilla
Old Sep 18, 2006 | 12:36 PM
1987LT250's Avatar
i did the same thing on my 87 lt250r that glass is your power valve glass not your oil glass. should say how much right above your fill hole. i never seen the oil in the glass eiether go figure lol.
Old Oct 17, 2019 | 05:57 PM
Lee Creemer's Avatar
1000ml. Says it on motor by oil cap
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
