LT500 pipe & porting
Old Oct 9, 2006 | 01:12 AM
Wolzzy's Avatar
Default LT500 pipe & porting
I recently bought an 89 LT500 and am looking for advise on a pipe & porting. Also carb and reed selection. Any help is appreciated
Old Oct 9, 2006 | 08:35 AM
pumpkin's Avatar
Go with CT racing for engine porting. As far as pipes paul turner makes an alright pipe. The best that I know is the FMF.
Old Oct 9, 2006 | 01:06 PM
Wolzzy's Avatar
I've never had luck making good power with an FMF. I'm not sure the engineering is there, especially on a modded engine. Seems more like a one pipe fits all type of deal.
Old Oct 9, 2006 | 05:00 PM
zilladragster's Avatar
Tony at T&N per did all my work. Very strong and reliable runs 4.5s 300ft stock frame +8 SWING ARM. Dq makes a very good in frame pipe. Tonys #801-731-5199.
Old Oct 9, 2006 | 11:38 PM
Wolzzy's Avatar
Thanks for the help.
Old Oct 10, 2006 | 01:15 AM
Duneaddict's Avatar
I see you've already found Doc (RK)... He's an absolute "Wizard" when it comes to the 500's.
I'll give a quick plug for his engineering work in pipe/port design and get off here...
All other pipes are sub-optimal in comparison. My old antique flat RIPS way better than I could ever imagine... Makes a stocker look like a 250. There is no other pipe available for the 500's that perform like his.... Period! Even the highly sought-after LRD wasn't even close.... (I sold mine on fleabay)
My motor is also ported to his specs and I couldn't be happier.
My $.02
Old Oct 10, 2006 | 01:34 AM
lt250rrider's Avatar
Hey I may not know much but you need to go to the lt250/lt500 page and speak with the DOC!!!! This man KNOWS his stuff and he makes his own pipes and can tell you everything you need to know about your zilla!!!!!!!!!!!!!
Old Oct 10, 2006 | 02:17 AM
Wolzzy's Avatar
At the risk of sounding stupid, where's the lt250/500 page?
Old Oct 10, 2006 | 02:28 AM
hey try google !!!!!!! Then tyre in lt250 Then I belive it is the first link!! It will also be like lt250/lt500 That is where the GREAT DR.Q is !!!!!! http://s15.invisionfree.com/LT250_LT500HQ/index.php try this
Old Oct 10, 2006 | 01:54 PM
Wolzzy's Avatar
Thanks, even with the sarcasm.
