quadzilla spitting oil, please help
Old Oct 11, 2006 | 09:57 PM
zquad's Avatar
Default quadzilla spitting oil, please help
I'm a new quadzilla owner and I have a problem. The quadzilla I bought is an 87' model, the motor has been reworked and ported. The motor runs great, starts great, and is very fast. When I was racing, I was giving it all it had and it spit out some oil from the exhaust where it slips onto the flange. It did this twice and it never stalled or anything like that. The quad was running a 430 main jet at 750' elevation and now its running a 390 main at 3800'. Is this oil from the pre-mix or what? I'm running 32:1. Please help...
Old Oct 11, 2006 | 10:24 PM
z250rida's Avatar
is the pipe on right?? if it is then make sure you are mixing the gas and oil right if u are then i have no clue
Old Oct 11, 2006 | 11:35 PM
zquad's Avatar
The pipe is on right and I mix with a ratio cup. Could I be running to rich, but all the top end power seems to be there?
Old Oct 11, 2006 | 11:56 PM
butters's Avatar
every 2 stroke leaks oil from the exhaust.....
get some high temp silicone and seal the connection up
Old Oct 12, 2006 | 12:06 AM
zquad's Avatar
Thanks, I just wanted to make sure I wasn't going to screw something up.
Old Oct 12, 2006 | 05:53 AM
pumpkin's Avatar
Ya my lt500 does the same thing. I didnt know if it was normal or not, but I rode the crap out of it anyway. It still runs.
Old Oct 12, 2006 | 12:10 PM
RK's Avatar
RK
Hi,
As the others have said, yes it's pretty normal to leak some 2-s oil from around the pipe/flange connection.
There is only 1 LT500 pipe that has a billet double o-ring flange that solves this issue.........
Enjoy your LT............ there's nothing like it.
RK
Old Oct 12, 2006 | 03:13 PM
allcool's Avatar
Some oil is normal, how much you got?
RK
What pipes do you now have in stock for lt500 ?
allcool
Old Oct 12, 2006 | 11:53 PM
zquad's Avatar
It just burps some out at WOT, I guess it was the remains of the YFZ I had just raced.[img]i/expressions/face-icon-small-happy.gif[/img] One more question, where can I get a DR Q exhaust from?
Old Jan 5, 2007 | 04:12 PM
CTATV's Avatar
from RK right?
ReconBayou
Oct 31, 2022 05:37 PM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
alzgarvin
Sep 11, 2015 08:53 AM
Slagpolaris
Sep 5, 2015 09:41 PM
