Lt250r : Clutch is sticking
Old Dec 3, 2006 | 07:49 PM
RappinErnie's Avatar
Default Lt250r : Clutch is sticking
Hey everyone, I'm just about finished restoring my Lt, and I fired it up today. I shut it off and checked the clutch. I put it in first held the clutch and kicked it, and the bike moves. I never took the clutch apart during the restoration. Does any one know whats wrong and how to fix it. I positive its sticking because when I tried to shift into 1st when it was running, the bike jumped and then stalled. It worked fine before I restored it to. Any help would be apritiated.
Mike
Old Dec 3, 2006 | 07:52 PM
pendejo's Avatar
There should be an adjustment on the clutch cable, see if you can adjust it to not jump while shifting at idle.
Old Dec 3, 2006 | 07:58 PM
I took off the cable and rigged up a wrench on the clutch and pulled it as far as it goes, it still slips though. I think maybe the plates are sticking? I'm not really sure.
Old Dec 3, 2006 | 08:05 PM
pendejo's Avatar
I think you are right. Pull the cover off and see whats going on. What kind of oil are you using for the transmission?
Old Dec 4, 2006 | 12:16 AM
I just drained the oil and put new tranny oil in. It's Bel-Ray Gear Saver 80w. The manual says 20w-40, but the guy at my dealer said this would work perfectly.
Old Dec 4, 2006 | 12:24 PM
pendejo's Avatar
Well, like I said, pull that cover off and see what going on. A clutch kit for that from Rocky Mountain is under $50 probably. I put the Tusk clutch kit in my 85 ATC and it's holding up nicely.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Levi Enstad
Sep 26, 2015 08:00 AM
jbrewster94
Sep 23, 2015 04:16 PM
Halffast17
Sep 11, 2015 02:30 PM
