05 eiger rear brakes
Old Dec 20, 2006 | 09:31 PM
sc's Avatar
sc
Default 05 eiger rear brakes
Is this an easy job, or should i take it in and have done. I have changed front pads, but never the rear.
Old Dec 20, 2006 | 10:34 PM
rolsmojave3's Avatar
You can take off the drum and look at it. They're not to hard if you can understand it
Old Dec 29, 2006 | 10:30 AM
jnt3000's Avatar
take a good look at it i just put new pads on mine but they still didn't work as good as they should . After looking at the two adjustment cables in the back, i still was able to tighten them as far as they would go and it still wouldn't lock up. So I removed the cables and removed the one bolt that holdes the arm in place. then you can slide it off and adjust it back about a 1/4 in. (they both have teeth on them so you can move them back) so now it gives me more room to adjust the cable. Worked great !!
P.S. This was the first time i did the back brakes and it wasnt that bad.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
baysport
Jul 23, 2015 11:37 AM
