first year z400
Old Jan 16, 2007 | 06:32 PM
Sandgod's Avatar
Default first year z400
Cams are slightly different along w/ a slightly bigger carb. The front shocks are fully adjustable and that's the biggest selling point.. I would still buy an older Z that is built up for less dollars.
Old Jan 18, 2007 | 10:07 AM
1988fast250x's Avatar
Where can i get the frame guesset kit from?? how much is it for the z400?? thanks
Old Jan 18, 2007 | 08:22 PM
ZButcheR's Avatar
QUOTE: crazy1291
how wide can you actually make a z400? whats the widest you can get it using A-Arms?, NO spacers on the front tho, that puts a lot of stress on steering components and increases bump steer,
Front of mine is 48" Rear is 50".. A-arms & A adjustable rear axle [img]i/expressions/face-icon-small-smile.gif[/img]
I got mine here BARE but thay were $55 when I got mine, looks to be $75 now
Old Jan 19, 2007 | 09:23 PM
crazy1291's Avatar
[quote]
IS YOUR BACK AXLE EXTENDED ALL THE WAY?
how low can you get a z400, 40" with 50" wide would be really nice centre of gravity
Old Jan 19, 2007 | 09:51 PM
  #15
ltz250rider's Avatar
dude i would deffinatly go with the ltz250 it handels great and has great power my bro got one last week and i got a z250 and we love it
Old Jan 20, 2007 | 12:29 PM
  #16
LTZGUY's Avatar
Go with a z250 over a z400.....yea right. a z250 is tippy, not near as comfortable, not as stable, does not handle near as well and is way underpowered compared to a z400. go ride one, you will see. I have both so I know.
Old Jan 20, 2007 | 02:16 PM
  #17
crazy1291's Avatar
dude im almost 6'2, i dont think a z250 would make the cut for not being tippy, sure its not tippy with a 4'8 rider on it but thats a whole different story, with me it would be top heavy, (and its only 42" wide?)
i want a quad that is at least 45 inches wide, but if its only 45" wide, then i want it no taller than 42"
Old Jan 20, 2007 | 02:39 PM
  #18
LTZGUY's Avatar
If you trailride more than race, get the z400. if you go to the dunes more than you trail ride, and your more worried about speed, get a 450. The thing I like about my 400 is the reverse and it has alot of aftermarket parts. It can easily be made to outrun a 450. I just put together a LTR450 engine for a friend and i ported the head, both engines are very similar. His intake/ehaust valves measured the exact sme as mine, the only difference was his were titanium. The combustion chambers were probably from the same casting. My intake/exhaust ports were slightly bigger and the 400 head has a lil more "meat" for porting than the 450. By summer time, i'll have the rest of the mods done to my bike and I'll be embarrassing quite a few 450's. Its all about combo/rider.
Old Jan 20, 2007 | 11:39 PM
  #19
crazy1291's Avatar
What are the bore and stroke on both quads, is the the ltr450 just a bored out or stroker version of the z400 or is it a combination of both?
Old Jan 21, 2007 | 12:33 AM
  #20
LTZGUY's Avatar
The bore/stroke on the z400: 90mm bore, 63mm stroke. LTr450: 95.5mm bore, 62.8mm stroke
Honda 450r: bore 96mm, stroke 62mm yfz450: bore 95mm, stroke 63.4 Hmmm, sounds like a 450cc big bore kit on a z400 would put it pretty equal. I really don't see why it would not.
Here are the weights of each quad:
honda 450r: 363lbs
yfz450: 350 lbs
Ltr450: 368lbs
Z400:373lbs...... yea the yfz is 23lbs lighter, but you can take a few things off the z400 and get it pretty close. I don't understand why the z400 does not get much credit....everyone says I should have got a 450. For less money I can make mine just as fast or faster and have a reverse, when mine is done....its going to be a sleeper.
