eiger stuck in 4x4
Old Jan 1, 2007 | 09:25 PM
jnt3000's Avatar
Default eiger stuck in 4x4
I just got back from riding and i cant get it out of 4x4 i tried putting it in reverse and turnig the weels but no luck. Whats the best way to see if it needs to be adjusted and where do you do it.
thanks for any help
Jeff
Old Jan 1, 2007 | 09:31 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Check out the 2wd/4wd lever on the bars. Open it up an look inside - there is a small white plastic cam that hooks to the 4wd cable. It's only about 3/8" long. If it breaks, the bike will default to 4wd. The part is not replacable - the whole lever assembly will need to be replaced. Runs around $85 IIRC.
You can also check where the cable hits the front dif to see if it's jammed with anything.
Jaybee
Old Jan 1, 2007 | 09:56 PM
jnt3000's Avatar
I took it apart and it looks like its ok. It looked like they switched it to metal. I took a Pic and loaded it on my profile to see if thats what you where talking about. I guess ill look at the other end of the cable in the morning. thanks for the help.
Old Jan 2, 2007 | 12:21 AM
Yup, that's what I was talking about. Glad to see that they made it metal.
I've never had to adjust my 4x4 cable, but I understand that it's done down at the bottom end. I would say that your problem is either the cable adjustment or a stick or other debris holding it in 4wd.
Jaybee
Old Jan 2, 2007 | 11:55 AM
jnt3000's Avatar
Flipped it over this morning and found the spot where you adjust the plunger that engages the 4x4. It seamed to be sticking a little bit so I sprayed it a bit with WD40 and adjusted it about a full turn and it works fine now. I loaded a picture of the plunger for the next person that has the problem (pics speak a thousand words) but it is very tight in there. The front nut is a pain to loosen, which allows you to tighten the back screw. Thanks again for the help, great forum.
Old Jan 3, 2007 | 12:11 AM
rolsmojave3's Avatar
You can adjust the cable right below the plastic, and above the tire (hidden by a rubber boot) also
Jeff Roper
Feb 1, 2022 11:48 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
