lt80 rattle noise
Old Jan 8, 2007 | 01:05 AM
raider450's Avatar
Default lt80 rattle noise
I would like to know if any have experience this problem.I have a 95 lt80 bike run fine but I hear a rattle noise comming around the piston area (it sound like if there is bolt loose)I rev engine up, gets a little louder.Checked all bolt,they check good including head bolt.Please help!Im getting my daughter bike ready for glamis.Thanks![img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 9, 2007 | 11:52 AM
LT80's Avatar
LT80 Expert
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
Do a compression check. Sounds like piston slap. Lets eliminate that aspect.
Clutch maintenence too.
Where you camp at Glamis? Gecko? Ogilby? washes?
Glamis rules!
Old Jan 9, 2007 | 07:15 PM
raider450's Avatar
thanks! I'll check compression.Bye the way,what should compression be at.what type of lube can I use to lube the roller on the clutch and do you need special tools to remove the clutch and if so where can I buy them?.Thank![img]i/expressions/face-icon-small-smile.gif[/img] (I dont know the location,but what I do know is near the restroom&showers every time we go to glamis.)
Old Jan 13, 2007 | 12:31 AM
raider450's Avatar
Ok! check compression is at 120psi.so now I check the roller and they where gumed up.Replase all roller and clean,But im having problems installing belt back on. please help!thanks![img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 13, 2007 | 11:38 AM
LT80's Avatar
LT80 Expert
Ya gotta squeeze it into the rear clutch. it should go on then., [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 13, 2007 | 02:13 PM
raider450's Avatar
Ok! lt80 thanks!ok this morning I bouble check my plate movable drive and face movable drive where realy damage.Called local dealer and the parts where discontinue.Can you help me out![img]i/expressions/face-icon-small-sad.gif[/img] or should I go with a aftermarket one.
Old Jan 13, 2007 | 02:25 PM
LT80's Avatar
LT80 Expert
Discontinued eh.....
There is nothing aftermarket for the clutchs. I can get any part in there I'm sure. Most are updated part numbers.
I'm not 100% sure of what parts you are talking about.
http://www.nrys.com/fiche_select.asp
Go there and get in the fiche and tell me what page and what number ie: 1-2-3-4-6,,etc..
You can order from there too. Ask for Jill.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 13, 2007 | 02:51 PM
raider450's Avatar
OK! found the web page, but I cant find fiche.Thanks!
Old Jan 14, 2007 | 01:36 PM
LT80's Avatar
LT80 Expert
You have to fil out the machine brand,model and year in the spaces provided.. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 15, 2007 | 01:43 AM
raider450's Avatar
thanks! lt80 found the parts from a dealer next city down from where i live.36.12 &4.23 total little more than 40.00 dollars out the door.[img]i/expressions/face-icon-small-smile.gif[/img]
