250r keeps fouling plugs
Yeah my plug is real black and wet with gas. I don't know what jets I have in it the guy I bought it from re jetted it. It has a full fmf exhaust, bored 10 over, k&n filter with no lid. When it does run it hesitates at the begining and screams past half throttle. Any suggestions on what size jetts to use. Thanks
Mine seems to be really fast when it runs right. I haven't had a chance to race anything big yet, but I have a warrior and it makes the warrior seem like it is sitting still. After about ten minutes of wide open runs my forearms stiffen up from holding onto the quad. This thing really rips when it hits the powerband. I have ridden raptors with all kinds of mods and they don't even come close to the Lt. The powerband is insane.
I always have had good luck running BelRay in Quadracers. Also, you are going to need that premium gas if there is a higher comp piston in it. I wouldn't just blindly run 87 unless you know for sure what it has. For the record though, 87 will burn hotter than the 92 you are running, and may help the fouling condition to a small degree if your engine can run it. It sounds like your pilot/needle/mix screw need to be adjusted. Start by pulling the pilot and go down one size, throw a fresh plug in and see if she doesn't run better.
My book says the stock jet is #240.This might kinda let you know how much they went up on jet size.If it hesitates at first,you might try lowering your needle down a notch or two.If this helps your hesitation and it keeps fouling plugs then you might try a smaller jet.If you dont know how to lower your needle then holler back at me.
Since your plug is black and wet, then you really need to pull the jets out and see what size you actually have in there. Then start trying different sizes. Every bike is different after some mods. My uncle and I are running the same setup on our 250R's, but mine requires a larger main jet than his. It is experimentation time.
