how to get a whellie on the ltz250
Originally posted by: Hamptonracing
you pop the clutches dumbass!!
One way that I found to do it was to put a foot in the grab bar and get your weight back and gas it. That give you the most control because you can lean back/give it more gas to go back, and if your back too far you can lean forward/let off the gas.
Another way is holding the shifter up in neutral or 1st, giving it some gas and then dropping it, which will put it in 1st or 2nd. That takes a little bit more time to figure out because you have to judge when your RPMs are just right. Too much gas and your going on the grab bar, or not enough and your only a couple of inches.
lol u guys pop the gears i used 2 do that but now i just slam the gas and pull back a lil and it pops it up in 4th sittin down my chubby friend does it in 5th on mine so just pull back and slam the gasd and eventually u will get it
