pics of ozark
Old Jan 23, 2007 | 12:05 AM
40smitty40's Avatar
Default pics of ozark
does anyone have a highly modified ozark, post your pics.
Old Jan 23, 2007 | 01:25 PM
GrnXnham's Avatar
Someone posted pics of a highly modified Ozark a few months back. Do a search and I'm sure you'll find it. It had a lift, 25" tires, a snorkel, and about 15 other mods. It looked pretty awesome.
Old Jan 30, 2007 | 03:01 PM
91CavGT's Avatar
That was mine. It has a few things done to it, and a few other things in the garage right now awaiting install like a pair of 25" X 9.5" X 12" Highlifter Outlaw tires!! Here's a pic of me going through a creek. Honest, there is an Ozark under there!!
2005 Suzuki Ozark 250
Old Jan 30, 2007 | 06:45 PM
40smitty40's Avatar
i was thinking of putting 24 inch mudlites with 10 or 11 inch aluminum rims on my ozark and was wondering if i will lose alot of power.
Old Jan 31, 2007 | 09:09 AM
91CavGT's Avatar
You will loose a little power but not too much. The larger rim will make the tire weight VERY similar to what the stock wheel/tire combo is. The biggest change you will see is that each gear will be longer than what it is now, and you'll have another 1" of ground clearance. If you do a lot of REAL low speed riding in 1st gear then you might not like it. But otherwise I have liked getting the taller tires on my Ozark.
What kind of riding do you do?
Old Jan 31, 2007 | 03:23 PM
paulatgis's Avatar
is 1" extra ground clearance really necessary? That is, do bigger tires perform better or just look better. 1" more on a 2wd ozark still leaves one without front wheel drive to pull over a log. How about just using 22" super swamp tires if they make them? The ozark already has 8 inch clearance, or so the specs say.
Old Jan 31, 2007 | 03:30 PM
91CavGT's Avatar
You would be surprised. Most of the big cc machines out there have 10" to 12" of ground clearance stock. So, when they start making some ruts, they are going to be anywhere from 10" to 12" deep. If you have 8" of ground clearance then it doesn't matter what kind of tires you have, you will high center your Ozark.
My Ozark has almost 11" of ground clearance at the back axle due to the taller tires. With the large tires, I don't high center nearly as often.
As far as getting over trees in the trail, it's no big deal at all. It's all about technique when dealing with a small ............... errrr........... ummm....... tool.
Old Jan 31, 2007 | 03:32 PM
ctateusa1's Avatar
The best thing about ground clearance is for riding in really rough terrain, I have taken my old 250 yamaha 2x4 into really bad places and have not needed 4x4 but I could have used more ground clearance to help out.
Old Jan 31, 2007 | 08:11 PM
40smitty40's Avatar
whitch rim would be better the 10 or 11 inch i will probally leave the front rims stock. unless it would be better to get new ones.
Old Jan 31, 2007 | 08:13 PM
40smitty40's Avatar
also if i did ever put i lift kit on it what are those custom suspension tethers. i read about those in another forum but i didnt really understand what they do where the go or stuff like that.
