pics of ozark
Old Jan 31, 2007 | 08:14 PM
91CavGT's Avatar
Default pics of ozark
The bigger rear rim you go with, the less the tire is going to weigh. Lighter weight tires will help to lessen the power loss from the larger tires. This is why I went with 12" rims with 25" tires on back.
Old Jan 31, 2007 | 08:17 PM
91CavGT's Avatar
Originally posted by: 40smitty40
also if i did ever put i lift kit on it what are those custom suspension tethers. i read about those in another forum but i didnt really understand what they do where the go or stuff like that.
With a lift, if your front wheels leave the ground then they drop down so far that the suspension can't do it's job (it binds up). So, when you come down it is VERY jarring and it will eventually destroy your ball joints.
The tethers I made prevent the suspension from dropping down when the front wheels leave the ground. This way, when the front tires hit the ground, it is nice and smooth because nothing binds up. I have had this lift on my Ozark for over a year now and have done some pretty serious riding with no problems from the ball joints.
Old Jan 31, 2007 | 09:36 PM
40smitty40's Avatar
do you have a pic of the tethers and can i fit 25 inch with out a lift
Old Jan 31, 2007 | 09:57 PM
40smitty40's Avatar
do you have any new pics of it with the new rims and tires on it
Old Jan 31, 2007 | 11:38 PM
  #15
91CavGT's Avatar
You can fit 25" tall rims up front with no lift, in the back is questionable. I had to trim a bit of the front egde of the fender to allow 25" tires to fit with a lift. Without a lift you'll probably rub on the top of the fender as well.
Oh, and yes I do have pics of the tethers, somewhere!! I'll have to dig them up.
I don't have any new pics with the new wheels and tires on it as of yet since the new tires are mounted on the rims, but the bead has not been set. I'm off of work this week due to a knee injury and am planning on working on it, but haven't gotten a chance to do so yet.
Old Feb 9, 2007 | 04:10 PM
  #16
AdrianXXX's Avatar
91CavGT: Have you already found some pics about 25" tires on Ozark?
Has somebody else? Thanks
Old Feb 10, 2007 | 10:55 AM
  #17
91CavGT's Avatar
Here is a pic of the suspension tethers I made..........
tethers 1
tethers 2
Here is the only pics showing my old 25" X 13.5" X 9" Super Swamper TSLs right after I got the lift installed. You can see how close they are to the plastic right behind your heels.
25" tires
Old Feb 17, 2007 | 11:36 PM
  #18
2006OZARKer's Avatar
i saw the picture of your lifted ozark. THATS AWESOME! how much $ have you put into that? i was really wondering if the T4 exhaust helped? how much did yours cost?
Old Feb 18, 2007 | 01:07 AM
  #19
91CavGT's Avatar
I have just over $1g put into my Ozark right now. That is all parts costs though as I have done all of the labor myself.
If I had another $1g to put into it, I'd get a cam, aftermarket CDI, high compression piston, and bigger carb.
EIF
Apr 20, 2017 07:15 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
clscott84
Sep 21, 2015 10:16 AM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
that1redhead
Sep 8, 2015 11:47 AM
