Oil return tank on Z400
Old Feb 15, 2007 | 02:04 AM
ThrashAndCrash's Avatar
Default Oil return tank on Z400
What is the reason for the oil return tank on the Z400????
Old Feb 16, 2007 | 06:19 PM
JkAss's Avatar
To **** us off and confuse us! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 16, 2007 | 08:03 PM
ss97's Avatar
Lets Ride!
You mean the oil reservoir tank?
The z400 is a dry sump engine so the oil circulates through a system from tank to engine, and back......
There is also a plastic PCV box up under the seat that is in the system.
Old Feb 16, 2007 | 09:19 PM
YEA the PVC tank.......The part is called "oil return tank" I was wanting to know what its real purpose was or can it be removed and install just lines instead of the bulky box......
Old Feb 17, 2007 | 10:44 PM
ss97's Avatar
Lets Ride!
The box is just an overflow and ventilator...
Like on an older car they had a PCV (Positive Crankcase Ventilation) valve usually running off the valve cover, the box is used as a vent in the system to allow excess air out of the system....
At least this is how it was explained me at the Kawasaki dealer when mine was replaced. It started leaking on about the 3rd ride. The tech told me there were a bunch of bad ones from the factory so they replaced it for me.
One nice thing about that system is that you can run a little extra oil without overfilling it. I know guy who race Baja/dessert type races and they will run an extra 1/4-to-1/2 quart of oil more so there is less breakdown. I don't know if it works but you know how racers will try anything to get an edge even if it is only in their heads....
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
