Eiger carb drain assist....
I'm draining the carb on Eiger for cleaning and this is the first time I've ever looked under the body at anything. Can anyone describe exactly where and what I'm looking for? Better yet, if anyone has any pics that would be awesome. Also, does it matter what setting I have the petcock on when I do it? I have it ON right now.
Thanks
Thanks
If youre just draining the float bowl of the carb, then use on or reserve on the gas tank valve, and on the very bottom of the float bowl is a slotted screw. There is also a rubber hose coming off the bottom of the carb, where the gas will flow out of. Unscrew that slotted screw about 2 turns, and th egas will start flowing. In about a half minute the bowl will be empty.
