Wiring for hand warmers??
Old Mar 18, 2007 | 09:45 PM
bongload's Avatar
Default Wiring for hand warmers??
what is the best way to hook up the wires??
Old Mar 19, 2007 | 12:04 AM
hondabuster's Avatar
There should be instructions with the warmers. It depends on whether the warmers use a resistor or not. Do the warmers have two wires or three, going to each grip?
Old Mar 19, 2007 | 07:51 PM
bongload's Avatar
2 wires to each grip. I was only wondering what would be the best place to hook up the positive wire?? Thanks!
Old Mar 20, 2007 | 02:45 PM
Most people string a new wire from the battery, with an inline fuse, of about 3 amps. You can also tap into the wire for the neutral light, its hot when the key is on. Make sure you tap into the wire before the bulb, not after.
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Austins
1) Engine problems..
Aug 9, 2015 02:28 AM
DeFox500
Jul 26, 2015 06:32 PM
ghost civic
Jul 19, 2015 10:13 AM
