Fuel Petcock problems...
The petcock on my Eiger will movely freely anywhere between RES and ON, but it will not turn to PRI. Is this supposed to be this way? It seems like it is supposed to stop right on RES or ON. Is the middle area between these two really the PRI position even though the label is on the other side? Or is something wrong?
I was able to drain the gas tank all at once by positioning the arrow between ON and RES, but it would cut flow whenever I moved to either ON or RES, it that helps at all...
fordfaithful21
12-07-2015 05:52 PM
