IRS lift kit
Old Apr 2, 2007 | 01:36 AM
allstar099's Avatar
Default IRS lift kit
Just woundering if anyone has put a lift on there King Quad.
-Just woundering how you like it
-If you've had any problems (cv's ect)
-How much work it was to install
Thanks
Old Apr 5, 2007 | 02:29 AM
muddingguy's Avatar
I put a two inch lift on my 05 KQ, easy to install. but the brackets seem to be to weak to do the job. first the right side bottom bracket broke, the one that holds the sway bar and tie rod, i fixed that and then the left side tie rod and bracket broke. if its made with stonger steel it will be great and other that stuff breaking i like the lift kit. I do put the machine through hell, so I haven't been suprised yet. If you ride easy you should have no problems.
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
