Z400?
Old Apr 27, 2007 | 10:29 PM
Partsstore's Avatar
Default Z400?
Ok guys, got a question.
Just built a Z400 to a Z485. +5mm stroker crank, hotcams, port polish, 95.5mm piston, DRZ valve springs, DRZ gaskets, 3 way valve job, Yoshimura RS3 full pipe, K+N air box lid and filter, Trail Tech Vapor guage, ESR mechanical guage, D.I.D cam chain, a 39mm FCR carb (guy likes to play in the woods) and many many more parts.
My question is what do you guys think about jetting. Were a Sudco dealer and talked to there tech department and they said a 195 main, 1 size larger on the pilot and 1 clip on the jet needle. There was a 165, went to a 170 main and its lean ( I can run full choke with no hesitation of the engine, running lean I know) Just curious to what you guys thought. Were at 950ft above sea level so no need for high elevation. And man this thing is is a ROCKET!!!!!!
So any info is appreciated! Also got a external adjusting fuel screw but will not work with the Sudco carb kit, huh? But all is good.
Thanks,
Nick
Old Apr 27, 2007 | 11:58 PM
cataway's Avatar
Default Z400?
are we going to see this thing a SL?
what tires you running?
Old Apr 28, 2007 | 12:36 AM
Partsstore's Avatar
Default Z400?
a SL? (Sleeper?) Confused. or (Silver Lake)
As far as tires, ill keep that as a secret right now [img]i/expressions/face-icon-small-wink.gif[/img] [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 28, 2007 | 06:04 PM
DVXDUDE's Avatar
Default Z400?
HOLY CHRIST, that thing must be a rocket.
I've never heard of anyone else having a 485. Only a 470 and that thing was spanking 450s with ease.
LETS SEE SOME PICS!!!!
Old Apr 28, 2007 | 10:30 PM
mucky's Avatar
Default Z400?
you can even buy the 536 stroker for it if you have lots of money and time. I had the 470 in mine till I blew it up over a month ago. it was fast, and I was running a 182 main in it, a 195 seems about right to start with
Old Apr 29, 2007 | 04:22 PM
Partsstore's Avatar
Default Z400?
Ya you are right, it is a ROCKET!!!! Got the jetting close, just need to put some time on the new engine then tune some more. The customer is really really happy!!!!! Ill get some pics up within a few days. Took lots for the customer per request. Now for the 400EX to 465EX with many many upgrades! Ill try to get pics of that one too when I get it done!
Mucky, what slow jet running in your 41 FCR?
Thanks for the info mucky!
Old Apr 29, 2007 | 05:21 PM
mucky's Avatar
Default Z400?
I think its a 55 and the needle is on the 5th clip. now with the 440 I had it dyno tuned and it has a 185 main a 52 pilot and the needle is on the 5th clip and it runs just as fast as the 470 did with out all the torque
Old Apr 29, 2007 | 05:39 PM
Partsstore's Avatar
Default Z400?
Ok thanks. How do you like your swingarm? Were going to be putting one on the quad and can only find 1.25+ longer than stock. I would really like to put a 2+ on the bike. Do you have a website that I can do some research with?
Thanks,
Nick (Partsstore)
Old Apr 29, 2007 | 11:18 PM
mucky's Avatar
Default Z400?
I like the swingarm I just wish it wasnt as heavy, the longer the arm the more it weighs, this is where i got mine from swingarm
arm
arm
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
