new 230 quadsport
Old May 5, 2007 | 01:33 AM
lanche's Avatar
Default new 230 quadsport
I purchased an 87 230 quadsport that wasnt running very well. The problem is when you go to start it it idles very high and of course that makes it hard to put it in gear.If you turn the idle down then it slowly will die out.I purchased and installed a new carb kit but it made no difference(new jets ,neddle etc.)I have all the plastic off and would like to check valve clearance and whatever else I can,Can anyone offer any suggestions and does anyone know the valve clearance,and also does it have a fuel filter of any sort.thanks for looking.
Old May 5, 2007 | 03:38 PM
AtomicPunk's Avatar
Valve Clearance
Intake 0.03-0.08mm (0.001-0.003in)
Exhaust 0.08-0.13mm (0.003-0.005in)
Your best chance for other answers are in this thread:
http://forums.atvconnection.com/mess...57/STARTPAGE=1
I think there are over 35 pages of good info..
Old May 7, 2007 | 10:53 PM
canheride's Avatar
hi there is the air filter drity, is the quad get the right amount from the tank. I know mines run high when she is about to give out of gas. Did u look at the low speed jet hole in the carb, if u take the jet out u can c a very small hole at the bottom were the jet surpose to be. i hope that my 1cent can help let me know
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
Nekolai1
Aug 25, 2015 10:04 PM
NatePerz
Jul 27, 2015 03:27 AM
rotaxtwin
Jul 1, 2015 07:15 PM
