1988 LT250R oil question?
Hey, I just bought this quad from a guy who was moving out of town. I forgot to get some needed information on the oil. What type of oil should be ran in the motor and what should be mixed with the gas and at what ratio?
Also, it has a bent tie-rod end what is the easiest way of replacing this back to stock position?
I'm the original owner of my 92 LT250R and from day one i have used__ 2 Stroke Oil: Maxima MTL at a mix of 32:1
Gear Oil: Maxima Endurance 85...And for the tie rod question js the rod it self bent ,or the adjusting ball joint ends,or are you having a alinment problem..05/31/07
Quadzilla Heritage
Sep 25, 2015 01:39 PM
