Help Needed - Oil Plug
Old Jun 20, 2007 | 05:02 PM
DChip's Avatar
Default Help Needed - Oil Plug
hey guys i need some assistance.
i was changing the oil on my ozark today. As i was reinstalling the oil bolt it seemed funny and wouldnt tightened. pulled it out and the threads on the engine part were flattened. Any solutions to this problem will be greatly appreciated.
Thanks,
DChip
Old Jun 20, 2007 | 05:20 PM
Fulltiltrider's Avatar
You will have to put a helicoil in it, or take somewhere to have it retapped
Old Jun 20, 2007 | 07:12 PM
GrnXnham's Avatar
I did the same thing on my Ozark. It's REAL easy to over tighten and I stripped it. I took it to the dealer and they put in the helicoil. Only cost me $20 to fix. After that, I now always use a torque wrench when tightening to keep from over doing it.
Old Jun 20, 2007 | 07:25 PM
DChip's Avatar
they funny thing is is that i didnt overtighten it. i hand screw the bolt in and when i went to tighten it with the ratchet it jus wouldnt tighten. I pulled it out and some of the threads were on the bolt and the inside looked like it was flattened, but the bolt is fine. tell me more about this helicoil
thanks
Old Jun 20, 2007 | 07:35 PM
ss97's Avatar
Lets Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: DChip
thanks</end quote></div>
A helicoil is basically a "coil" looking hollow threaded bolt that will basically re-thread the stripped hole. They come is a kit with multiple sizes. The coil threads into the hole, and then the bolt threads into the coil.
Having the hole retapped, and getting a new drain plug is also an option.
Old Jun 21, 2007 | 11:16 AM
DChip's Avatar
hey guys,
could you also tell me how i measure my bolt
thanks
DChip
Old Jun 21, 2007 | 06:41 PM
ss97's Avatar
Lets Ride!
The best way to measure IMO it to go to an auto parts store and buy a cheap bolt gauge. They are usually plastic and cost about $5-$10 bucks or so. They generally have holes on one side to measure the size (in MM and in std) and then there is usually a thread feeler on the side to measure the thread count as well (1.00 or 1.50 etc.).
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
WilliamBos
Sep 30, 2015 08:08 AM
Big600twin
14
Jun 16, 2015 09:30 AM
rapple
Jun 2, 2015 01:38 PM
