300 King Quad Blowing smoke
Old Jun 21, 2007 | 08:36 PM
PETEinNY's Avatar
Default 300 King Quad Blowing smoke
My 1999 300 King Quad is blowing a tremendous amount of smoke. It appears that I fried the rings or maybe even worse. There is no engine knock. Would a new piston and rings cure this? Or would I need a complete engine rebuild. Does anybody know what type of money this would bring?
Old Jun 21, 2007 | 09:05 PM
Z400MANIAC's Avatar
the new pistons and rings would cost like 350 and the new engine would be about 17-2100
Old Jun 21, 2007 | 10:58 PM
buckaroo50's Avatar
I would start with a compression test. Test it dry and then put about an oz of Marvel Mystery Oil in the sparkplug hole and test it again and compare. Compare it to the specs for the engine too - probaly someplace between 70-110psi would be ok. If the compression is there, then the problem is probably not as serious. Might be just a case of bad valve seals or such.
Problem: Exhaust smoke dirty or heavy
Condition Remedy
1. Oil (in the engine) overfilled - contaminated 1. Drain excess oil - replace oil
2. Piston rings - cylinder worn 2. Replace - service rings - cylinder
3. Valve guides worn 3. Replace guides
4. Cylinder wall scored - scuffed 4. Replace - service cylinder
5. Valve stems worn 5. Replace valves
6. Stem seals defective 6. Replace seals
Old Jun 22, 2007 | 03:57 PM
PETEinNY's Avatar
Thanks for the feedback.
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
D-Hagz
Jul 4, 2015 02:19 AM
