running rich
Old Jul 29, 2007 | 11:37 PM
ruffroad's Avatar
Default running rich
I have a 1996 LT250-4WD. I bought it in 1999 and within a couple of years it began to run a little rich. It has gotten progressively worse over the years. I rebuilt the carb a couple of years ago but it didn't help. With a new spark plug it runs OK, but as it gets warmer it runs richer. When the spark plug begins to foul it runs worse, and will get to the point that it won't start until you change the plug. Is there something in these carbs that wear out and replacement parts aren't in the rebuild kit? Other ideas? Any help would be appreciated. thanks.
Old Jul 29, 2007 | 11:53 PM
Doctorturbo's Avatar
GOT BOOST!
Do a compression. I bet the number will be low.
Old Jul 29, 2007 | 11:59 PM
ruffroad's Avatar
Ouch! that wasn't the answer I wanted to hear, but it does fit the symptoms.
I'll check it out. thanks.
Old Jul 30, 2007 | 12:10 AM
GOT BOOST!
Ya I know. I had the same deal going on with a golf cart. Very rich, hard to start, yada, yada, yada. Took a compression and it was 40PSI. Changed everything out except the cases and now it runs super!!!
Good luck; hope I'm wrong and it just needs an adjustment.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
robj
Jun 15, 2015 08:45 PM
Chawness
Apr 21, 2000 08:14 AM
