cam position
Old Aug 5, 2007 | 11:35 PM
chaoflux's Avatar
Default cam position
my buddy is putting his 2005 ltz 400 back together and was wondering what the position of the cams should be.
any help would be great
thanks
Old Aug 6, 2007 | 04:05 AM
poorboysllc's Avatar
when looking at the cams with top cover off the engine. the cam gear on the right it has a #2 on it and needs to be at 12 o'clock and the cam gear on the left has a #3 on it and it should be @ 12 o'clock also
the cam gear on the right will line up with your first pin and 15 chain pins back "left" will be where you line up your left gear on #3
As far as the bottom gear you have to align the "t" line on the generator rotor with center of the generator cover "that its on the other side of the engine"
keep chain tight going counter clockwise as you are installing the chain this will help
if anything else i might be able to help
Dammar
Apr 20, 2016 06:03 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
lgardner61980
Sep 20, 2015 01:32 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
