quadracer gas mix ratio
Old Oct 3, 2007 | 05:00 PM
white_scramby's Avatar
Default quadracer gas mix ratio
Hey guys. I have a 86 quadracer. Im trying to figure out wat mix ratio i should use. I've been told 32: and 40:1? What about 25:1? Im pretty sure its runnig rich right now cuz i have oil coming out of the exhaust connections. (if thats what it is???? any ideas or suggestions would be awsome.
Thanks
Old Oct 3, 2007 | 07:11 PM
minnzilla's Avatar
I would suggets that you use a 1:32 ratio. I have been running this in my quadracer for many years with no issue. Do you use amsoil. I would suggest it as the best premix. Running addional oil in the gas will not make the machine run rich in fact as you add oil you reduce the amount of gas in the mix and lean out the motor. All of my quadracers spit oil from the connection to the expansion chamber no way to stop that - I have tried gaskets and pentex grey with no luck. Just need to keep cleaning. Good luck
Old Oct 3, 2007 | 08:57 PM
Scooter86's Avatar
Knows Old ATV Questions!
Minnzilla is right on. I have an '85, and Suzuki actually recommended 24:1 for it. After asking around, I ran mine on 32:1 and it works great. You are always going to have a little 2-stroke drool with one of these engines so don't worry about it.
Old Oct 4, 2007 | 02:06 PM
bigned1904's Avatar
when i had my quadracer i always ran it 32:1.
Old Oct 8, 2007 | 08:04 AM
Camo-man's Avatar
I run 32:1 Using MAXIMA Smokless.... runs great.... The crud droll is due to jetting....I'm trying to get a grip on my jetting now...
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
