z400 cutting out?
Old Oct 20, 2007 | 03:11 PM
POSz400's Avatar
Default z400 cutting out?
I have an 04 Z400/kxf400. it cuts out at high rpms it runs fine at idle and just cruising but when you get on it it dies or cuts out. i have put new plug in it and a new stator and cdi box. any other suggestions?
Old Oct 21, 2007 | 03:34 AM
AIRMOBILE101's Avatar
If your cutting out at high rpms, you probably need to re-jet the main jet. Have you performed any mods to the bike?
Old Oct 21, 2007 | 07:06 AM
nedflanders's Avatar
high end sounds like plugged main jet. clean the carb.
Old Oct 21, 2007 | 09:26 AM
AZZukR450's Avatar
Sounds like a jetting issue...
Old Oct 21, 2007 | 04:24 PM
POSz400's Avatar
i gutted the factory pipe. other than that is is stock. the carb has been cleaned. it was running fine till i took it apart to paint the frame. i left the back end lifted in the air over night and when i put it bak together. thats when it started.
Old Oct 21, 2007 | 08:58 PM
Yea, you need to re-jet the main to a larger size.
Old Oct 22, 2007 | 01:05 AM
mucky's Avatar
rejet the carb. larger main jet
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Elkaholic
Sep 6, 2015 02:44 PM
