Gear OIL?
Old Nov 1, 2007 | 09:28 AM
Bobbycfh's Avatar
Default Gear OIL?
I just bought a 2005 Suzuki Vinson a few months ago and was gonna change the oil in the front and rear Differential. My question is what weight oil should I use? Ive been looking online and havent been able to find anything on it
Old Nov 1, 2007 | 07:39 PM
BradW's Avatar
Default Gear OIL?
90 weight gear lube should be fine.
Old Nov 1, 2007 | 08:15 PM
OhHell's Avatar
Default Gear OIL?
Just make sure it has a GL-5 rating.
Old Nov 2, 2007 | 03:50 AM
GrnXnham's Avatar
Default Gear OIL?
I changed mine using Honda gear oil
Old Nov 3, 2007 | 12:24 PM
TeamMudd's Avatar
Default Gear OIL?
the manual states to use SAE90w hypoid gear oil with a GL-5 rating. if you operate under 0 degree temps to use SAE80w hypoid gear oil.
i changed mine with a synthetic 80w140 gear oil. if you use a regular SAE 80/90 weight oil, be sure to add some friction modifier to the front diff for the limited slip. i found some 80w140 Valvoline synthetic at advanced for $12/qt so that was just as good as ordring the high dolor stuff from summit or jegs!
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
