teather kill switch
Old Nov 8, 2007 | 03:59 PM
freightshaker's Avatar
Default teather kill switch
i put a teather kill switch on my z400 and every time you pull the teather to kill it the fuse by the battery blows anybody no if this normal thanks for any help.
Old Nov 11, 2007 | 06:48 PM
Airbrushhead's Avatar
Sounds like you got your wires crossed. When tethered is pulled, it should create a ground. Sounds like you got a hot wire turning into ground when pulled thus blowing a fuse. You can wire it up hot also, so when the tethered is pulled it breaks the current.
Hope this helps.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
