1988 suzuki lt-f250j quadrunner
Old Nov 13, 2007 | 01:30 PM
brown1's Avatar
Default 1988 suzuki lt-f250j quadrunner
Can Someone Please Tell Me,How To Check The Timeing,On A Suzuki 1988 Lt-F 250J Quadrunner? Thanks
Old Nov 13, 2007 | 05:28 PM
JustRandy's Avatar
The ignition timing is not adjustable, so no easy way to check it. The valve timing is checked by looking at the cam sproket when the piston is at TDC. The sproket should have marks that are parallel to the head I think. Either that or it will have a dot that should be straight up. Either way, it will be pretty obvious once you take a look at it. There are other guys here that can tell you exactly.
You can look at the spark plug to determine if the timing is correct. The ground strap should have a color difference in the middle of the curve. It should be right in the middle. If not, the ignition timing is off.
Old Nov 13, 2007 | 10:25 PM
brown1's Avatar
Thanks JustRandy
Valder
Nov 28, 2020 07:38 AM
Dammar
Apr 20, 2016 06:03 AM
merryman
Sep 19, 2015 03:15 AM
phummer3210
Sep 11, 2015 03:47 PM
Sep 1, 2015 11:59 PM
